It is currently Mon Nov 23, 2026 9:00 pm
Post new topic Reply to topic  [ 51 posts ]  Go to page Previous  1, 2, 3
 Post subject: Re: New Theme I've Been Working On
PostPosted: Wed May 28, 2014 12:46 am  (#41)
Just started to have a go at this. I looked everywhere in the gimp 2.8 folder and couldn't find the file. So I did a search and found one that is apparently a pdf but will not open? It is only 430 bytes.
PostPosted: Wed May 28, 2014 2:53 am  (#42)
You should have a gtkrc in your personal .gimp-2.8 folder (mine is 616 bytes), but this has very little in it to customise.
You would be much better off downloading an existing theme into your personal themes folder and then working on a copy of that. As Warrior says, keep the original untouched as a reference.
In a short investigation, I've found the Stonewashed theme to be the most functionally complete on my Windows machines: http://thegimp.ca/gimp-2-8-dark-theme-stonewashed/
Oh, and because the gtkrc file doesn't have a file extension (.txt .csv etc) it might be difficult to associate with an application to open it, so I'd advise opening the text editor of your choice first and loading the gtktc from there.
Kevin
PostPosted: Wed May 28, 2014 6:14 am  (#43)
Kevin
All around good advice. I started with the Greenheart theme, and modded it.
PostPosted: Wed May 28, 2014 6:14 am  (#44)
Thanks, I'll have another look
PostPosted: Wed May 28, 2014 6:16 am  (#45)
Graechan wrote:
Warrior were hoping you will release soon for all to try
It'll be soon my friend.
PostPosted: Wed May 28, 2014 6:27 am  (#46)
Mine is 430 bytes also sallyanne. Just right click the file and click open with notepad, or whatever your editor is. Mine is Gedit in Linux.
PostPosted: Wed May 28, 2014 7:00 am  (#47)
I like the bow and eyelashes Molly
PostPosted: Sun Jun 08, 2014 1:16 am  (#48)
Gonna release this in a few days. I think I have all the bases covered. I'll start a new thread for it.
PostPosted: Sun Jun 08, 2014 2:26 am  (#49)
I'm looking forward to that.
One of the things that caught me out was the curves tool - I had managed to make the grid lines, the curve and the mouse pointer the same colour as the background so they disappeared completely!
Kevin
PostPosted: Sun Jun 08, 2014 8:25 am  (#50)
Kevin
Haha, that's awesome. I had to darken the bg a little, so the lines would show, haha.
PostPosted: Sun Jun 08, 2014 3:59 pm  (#51)
Released: viewtopic.php?f=11&t=10505
