It is currently Wed Sep 23, 2026 7:36 pm
 Post subject: How can I create a 'visible layers list'?
PostPosted: Thu Dec 19, 2013 6:11 am  (#1)
I'm looking for a way to create a 'visible layers list' at the start of a script because after that i have to set all the layers invisible;
then at the end of the script I can set all the layers from the 'visible layers list' visible
 Post subject: Re: How can I create a 'visible layers list'?
PostPosted: Thu Dec 19, 2013 7:03 am  (#2)
I think that you get a list of all the layers, then scan through that list applying gimp-drawable-get-visible and if it returns TRUE, then add it to a new list.
Kevin
PostPosted: Thu Dec 19, 2013 7:03 am  (#3)
:ninja
You could just loop through all the layers and check to see which are visible with gimp-item-get-visible, then save those layers in a vector using gimp-image-get-active-layer.
At the end of the script, loop though the vector and make each of stored layers visible again using gimp-item-set-visible. Maybe there is a more efficient way but that's what I would do.
PostPosted: Thu Dec 19, 2013 7:21 am  (#4)
visibleLayers=[layer for layer in image.layers if layer.visible]
But I don't see the purpose of this unless you are trying to emulate an animation by uncovering the layers one by one?
PostPosted: Thu Dec 19, 2013 7:47 am  (#5)
(set! layerList (vector->list (cadr (gimp-image-get-layers image))))
(set! visibleList (vector->list null)
(while (not (null? layerList))
(set! layerId (car layerList))
(if (= (car(gimp-drawable-get-visible layerId)) true)) (set! visibleList (+ visibleList layerId))
(set! layerList (cdr layerList)))
the highlighted section is what I'm not sure of,(e.g. how to add new layers to an existing list)
PostPosted: Thu Dec 19, 2013 7:51 am  (#6)
Probably having different layers opening on a canvas that shows them all simultaneously?
Each layer staying visible on the canvas as they open 1 at a time.
My guess anyways. Could be a lot of uses for that. Loading bars for 1.
PostPosted: Thu Dec 19, 2013 8:13 am  (#7)
To add a new element to a list of elements, you would use 'cons', which is short for "construct". The new element is placed at the front of the list (to avoid having to walk along the length of the list to find its end).
The following code snippet uses "named let" to loop through each of the layers. This is generally considered preferable to using "while" loops since there is no need to use 'set!' to change the state of a variable. Note that I use 'reverse' on the final list of visibles to maintain the top-to-bottom ordering of the layers (this is necessary because 'cons'ing builds the list in reverse order).
(let ((visibles (let loop ((layers (vector->list (cadr (gimp-image-get-layers image))))
                           (visibles '()) )
                  (if (null? layers)
                    (reverse visibles)
                    (loop (cdr layers)
                          (if (zero? (car (gimp-drawable-get-visible layer)))
                            visibles
                            (cons (car layers) visibles) ))))))
  ; To hide all of the originally visible layers
  (map (lambda (x) (gimp-drawable-set-visible x FALSE)) visibles)
  ; DO STUFF HERE
  ; To restore all of the originally visible layers to being visible
  (map (lambda (x) (gimp-drawable-set-visible x TRUE)) visibles)
Alternately, you could use 'for-each' instead of 'map'. 'for-each' is acceptable whenever you don't care about the result being returned which is the case here; however, I just prefer to use 'map' since it works either way.
Another approach to obtaining the visibles is to use folding. Script-fu's 'foldr' function is not exactly the same as the traditional 'fold-right', but it does serve the same purpose.
(let ((visibles (foldr (lambda (a x)
                         (if (zero? (car (gimp-drawable-get-visible x)))
                           a
                           (cons x a) ))
                       (reverse (vector->list (cadr (gimp-image-get-layers image)))) )))
PostPosted: Thu Dec 19, 2013 8:19 am  (#8)
Graechan, come to the dark side of python-fu(*) :)
Otherwise see: http://en.wikipedia.org/wiki/List_comprehension#Scheme
(*) and the the 21th Century, 3rd millenium, etc...
PostPosted: Thu Dec 19, 2013 10:02 am  (#9)
Hi Graechan.
Saulgoode and the others who replied before me have already given you suitable advices on how to proceed, so I have nothing to add in this regard.
However, just one last remark: when you operate in GIMP 2.8 and above and you deal with an image fitted with one or more layer groups, notice that the "gimp-image-get-layers" procedure alone is not enough to detect and list all the layers in the image, since it can only return those placed in the main stack, while omitting the ones embedded in groups at any level of nesting.
So, in that case, you ought to recursively invoke the "gimp-item-get-children" procedure whenever a layer group is detected during the loop in order to make sure to trace every layer in each group.
If you are interested, take a glance at this procedure that I implemented in my "Identify Image Objects" script just for working around the aforesaid limitation of the "gimp-image-get-layers" command, where you can see that it produces the very same type of output, namely a list containing the actual number of layers alongside the array with their identifiers:
(define (gimp-image-get-nested-layers image)
  (letrec
   ((find-children
     (lambda (layer-ids k n)
       (if (< k n)
           (let* ((layer-k (vector-ref layer-ids k)))
             (append
              (cons layer-k
                    (if (= (car (gimp-item-is-group layer-k)) TRUE)
                        (find-children
                         (car (cdr
                               (gimp-item-get-children layer-k)))
                         0
                         (car (gimp-item-get-children layer-k)))
              (find-children layer-ids (+ k 1) n)))
    (let* ((all-layers
            (apply vector
                   (find-children
                    (car (cdr (gimp-image-get-layers image)))
                    0
                    (car (gimp-image-get-layers image))))))
      (cons (vector-length all-layers)
            (cons all-layers
PostPosted: Thu Dec 19, 2013 11:20 pm  (#10)
Saulgoode everything was OK untill it came time to set the visible layers visible again, probably because the
visible list should not contain the drawable Which is the active layer below is the code I used
(gimp-drawable-set-visible drawable FALSE)
  (let ((visibles (let loop ((layers (vector->list (cadr (gimp-image-get-layers img))))
                           (visibles '()) )
                  (if (null? layers)
                    (reverse visibles)
                    (loop (cdr layers)
                          (if (zero? (car (gimp-drawable-get-visible drawable)))
                            visibles
    (gimp-drawable-set-visible drawable TRUE)
the reason for this is that the drawable Id is changed during the script
PostPosted: Fri Dec 20, 2013 12:04 am  (#11)
Correct. You can remove the active layer from the list with 'delq':
(set! visibles (delq drawable visibles))
The drawable ID will change if you perform a Merge Down or a Merge Visible Layers. It also changes when certain filters are run (but this is fairly rare). As long as you remove the original drawable's ID from your list of visibles before unhiding them, you should be fine.
PostPosted: Fri Dec 20, 2013 12:51 am  (#12)
Saulgoode you are right as I need to use both Gmic and merge visible layers on the drawable it didn't stand a chance of keeping its Id
PostPosted: Fri Dec 20, 2013 1:34 am  (#13)
Saulgoode worked OK but at the end when I restored the visible layers it set all the layers visible
entire code below
;;;; set all layers except drawable invisible
                           (visibles '()) )
                  (if (null? layers)
                    (reverse visibles)
                    (loop (cdr layers)
                            visibles
;;;;begin the script
   (let* (
         (copy-layer (car (gimp-layer-copy drawable TRUE)))
       (before (vector->list (cadr (gimp-image-get-layers image))))
       (after 0)
    ;; Add a copy of the layer to the image.
    (gimp-image-add-layer image copy-layer -1)
    ;; Render Split Details from the active layer, using G'MIC.
    (plug-in-gmic 1 image drawable 1
                  (string-append
                   "-v - " ; To have a silent output. Remove it to display errors from the G'MIC interpreter on stderr.
                   "-split_details "
                   (number->string nbs) ","
                   (number->string ratio) " -+[^0] 128 -c 0,255 -reverse"
   (set! after (vector->list (cadr (gimp-image-get-layers image))))
   (map (lambda (x) (if  (eq? (member x before) #f) (gimp-layer-set-mode x GRAIN-MERGE-MODE))) after)
   (set! drawable (car (gimp-image-merge-visible-layers image EXPAND-AS-NECESSARY)))
    ) ;end gmic variables
    ) ;endlet for visibles
   (gimp-displays-flush)
   (gimp-image-undo-group-end image)
   (gimp-context-pop)
) ;end variables
) ;end procedure
somehow the visibles list included invisible layers
PostPosted: Fri Dec 20, 2013 1:48 am  (#14)
Oops! I made a mistake in my code. Here is what it should be (the reference to 'drawable' should be to the first layer in the list of layers):
                           (visibles '()) )
                  (if (null? layers)
                    (reverse visibles)
                    (loop (cdr layers)
                          (if (zero? (car (gimp-drawable-get-visible (car layers))))
                            visibles
Sorry about that.
PostPosted: Fri Dec 20, 2013 2:26 am  (#15)
Thank you Saulgoode everything OK, I look at this as my education on lists and they are interesting to use :bigthup
