It is currently Tue Nov 24, 2026 2:39 pm
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: updated- Costrast Swiss Mask
PostPosted: Sun Dec 19, 2010 7:13 am  (#1)
NEW VERSION now with option for split preview
Gmic -Contrast Swiss Mask by PhotoComiX, on Flickr
A very simple filter with not too much options or controls
..but maybe the first complete digital application of Contrast Mask ,as was used in Darkroom
....weird that all other Contrast Mask filters are limited to only lower the contrast, should be obvious that the same principle used to locally lower the contrast , may be well used also to locally increase the contrast.
Obviously a Contrast Mask is a a very simple way to manipolate the contrast but Smay be very effective
As default works as a Contrast Mask:
if the original is
DSC00138-S.jpg by { pranav }, on Flickr
Then the result would be
But the same mask could be used to get the opposite effect
If you check the SKIP button ...then the effect will be the opposite of a traditional Contrast Mask
WHAT SKIP DOES
ORIGINAL
Untitled by jared, on Flickr
Default -NO "skip " option checked
Contrast Swiss Mask - NO skip by PhotoComiX, on Flickr
SKIP enabled
Contrast Swiss Mask -Skip by PhotoComiX, on Flickr
ORIGINAL
Nuclear Winter in Chernobyl by Stuck in Customs, on Flickr
SKIP enabled
#########HERE#THE#FILTER###############################
#@gimp Contrast Swiss Mask : gimp_contrast_swm2 , gimp_contrast_swm2_preview(0)
#@gimp : sep = separator ()
#@gimp : Blur the mask = float(2,0.5,10)
#@gimp : note = note ("Contrast Mask need the negative of the mask")
#@gimp : SKIP to use the mask to boost = bool(false)
#@gimp : note = note ("Uncheck for Contrast Mask,Check for Contrast Boost")
#@gimp : note = note("Merge the Mask")
#@gimp : Intensity = float (1,0,1)
#@gimp : Preview type = choice("Full","Forward horizontal","Forward vertical","Backward horizontal","Backward vertical")
#@gimp : sep = separator(), note = note("<small>Author : <i>PhotoComiX</i>. Last update : <i>2010/12/26</i>.</small>")
#@gimp : note = link("Filter explained here","http://www.gimpchat.com/viewtopic.php?f=9&t=864")
gimp_contrast_swm2 :
-repeat @# -l[$>] -split_opacity -l[0]
--luminance -to_rgb
-blur_xy[1] $1,$1
-if {$2==0} -negative[1] -elif {$2==1} -gimp_do_nothing -endif
-reverse[-2,-1] -gimp_compose_hardlight[-2,-1] $3
-endl -a c -endl -done
gimp_contrast_swm2_preview :
-gimp_split_preview "-gimp_contrast_swm2 ${1--2}",$-1
###########END#############
Here the Controls
GMIC - Contrat Swiss Mask-updated by PhotoComiX, on Flickr
The first slider control the blurring of the mask,
default is a good starting point you may raise for large or very large images
Note well the Skip option allow to use the mask for the opposite effect, see below
Last slider control the intensity of the Effect,
More exactly allow to fade the effect over the original
( with Intensity 0 would be no any change )
ORIGINAL
Contrast swiss mask test - ORIGINAL by PhotoComiX, on Flickr
"SKIP" box checked (boost, opposite effect )
Contrast swiss mask test -boost by PhotoComiX, on Flickr
THE DEAFULT (mask)
Contrast swiss mask test - mask by PhotoComiX, on Flickr
Normally the contrast mask is used to locally decrease contrast to recover details in overcontrasted zones
Here the details on the right side (inside the blue box and on that side of the wall ) are burned or washed away beyond hope, so the effect of the the default setting are mainly visible on the lef side were is more to recover
ORIGINAL
Christmas Beer by thskyt, on Flickr
DEFAULT
LAST CONTROL is for the type of preview, as default is normal but you may get a horizontal or verical split preview , showing the before after as here
 Post subject: Re: New For GMIC : Contrast Mask/Boost
PostPosted: Sun Dec 19, 2010 12:46 pm  (#2)
Hey PC; haven't played with you Script yet, but I like to use Lumina Invert (a Script-fu I ran across a few years back) on a duplicate top layer and set that layer property to Overlay. Really oversaturates the colors as well as gives you the contrast mask effect. :)
PostPosted: Sun Dec 19, 2010 12:58 pm  (#3)
This works splendidly, PC. Thanks!
PostPosted: Sun Dec 19, 2010 8:04 pm  (#4)
i think is the same idea
As default it works as you will expect from a contrast mask, but will do the opposite checking a box
Here i used on a 3900x2600 photo with default
ORIGINAL
Hot Rod by dave_7, on Flickr
DEFAULT
Contrast Mask/Boost -Default test by PhotoComiX, on Flickr
PS maybe i will add a option for "Dark Sharpening"
PostPosted: Sun Dec 19, 2010 8:51 pm  (#5)
New name
"Contrast Swiss Knife" ,now with :wh Dark Sharpener :wh included... :paint
PostPosted: Mon Dec 20, 2010 6:56 am  (#6)
I like the name! :clap
PostPosted: Mon Dec 20, 2010 7:07 am  (#7)
PhotoComix wrote:
New name
That's a bit ominous sounding. I love it! :clap
PostPosted: Mon Dec 20, 2010 11:22 am  (#8)
No there are 2 too good competitors as Curve and level for the Contrast Swiss Knife honorificence
Better :drum "Contrast Swiss Mask" :drum
PostPosted: Mon Dec 20, 2010 1:18 pm  (#9)
Former Member
WOW this is very nice, can't wait to give it a try. Is this in the current version, or no, also when's the next release???
PostPosted: Fri Dec 24, 2010 11:16 pm  (#10)
New version on first message
Often are the simplest things to work better ,so instead than add more options i simplified, and fixed a bug
@mikethedj4
To install extra gmic scripts you may just create a file called .gmic in C: Documents and Settings/ yourname/ application data and paste there the script you wish to add
Even more simple in linux...just add the .gmic file in your home directory
PostPosted: Fri Dec 24, 2010 11:42 pm  (#11)
Oh, I've been waiting for it to show up in g'mic. Obviously I've been wrong.
PostPosted: Sat Dec 25, 2010 7:55 am  (#12)
maybe in the next version
Personaly i am happy that was not yet included because of that bug solved only now.
And i must fix some details alsoin the others i did
(hem..were fixed but seems i deleted the correct version and uploaded a draft :gaah
they do work well except for a option that also add a unrequested extra layer...good thing is that it is hidden behind the correct layer)
I feel a bit as in front of a fork, i can not hope to do much more without learn some basics of programming and get much more confidence with command line.
On the other side my only interest in programming is to create a few filter and tool that don't exist yet or not as i wish ;
there are not so much left ... and what left ( a good Kaleidoscope filter , similar to the Medhi PS plugin) looks very difficult
well ...before Easter i want a Eggify filter, but as now is not on top of my priority
So as now i plan just to perfect what i did till now ( already 5 ,Graphic Boost 1 & 2, Kool Draft, Realistic Painter , and this one )
PostPosted: Sat Dec 25, 2010 10:10 pm  (#13)
Have a look to the first message
 Post subject: Re: GMIC : Contrast Swiss Mask UPDATE 1/1/2011
PostPosted: Sat Jan 01, 2011 8:45 pm  (#14)
updated
see first message
PostPosted: Sat Jan 01, 2011 10:49 pm  (#15)
I added both to my .gmic file PC, these are splendid man! =)
Thank you.
PostPosted: Sat Jan 01, 2011 11:35 pm  (#16)
Glad you like Rod :yes
PostPosted: Wed Jan 05, 2011 8:40 pm  (#17)
NEW VERSION now with option for split preview as
if the original is
WHAT[b] SKIP DOES[/b]
ORIGINAL
SKIP enabled
ORIGINAL
SKIP enabled
--luminance -to_rgb
-blur_xy[1] $1,$1
###########END#######################
PostPosted: Wed Jan 05, 2011 8:48 pm  (#18)
Oppss i messed up a bit with the image links, now is fixed
 Post subject: Re: updated- Costrast Swiss Mask
PostPosted: Wed Jan 05, 2011 9:30 pm  (#19)
Fantastic PC! I grabbed it up.
Did you get any sleep yet? =)
PostPosted: Wed Jan 05, 2011 10:19 pm  (#20)
i stumble upon something i want add a option for "Synbiotic Merging" :geek
(I just inade up in my mind the the "Synbiotic Merging" you will not find on a wiki)
seems warking well manually :flirt
well different will be subtle but maybe cool compensate a bit possible colours shifts
NOW
Synbiotic Contrst Mask
Main differences in sky & the whitesh cloths
